Best lift for 33" tires
Although I have a 2 dr. I added TF full puck leveling kit with 18/59 springs running 32's. I did have 14/55's originally.
First two next to stock 4 dr's with 255's
Next to 4 dr with TF BB and 285's
Don't know if this helps, but it might give you another option.
Read this as well.
https://www.jk-forum.com/forums/modi...bie-has-18617/
Read this as well.
Although I have a 2 dr. I added TF full puck leveling kit with 18/59 springs running 32's. I did have 14/55's originally. First two next to stock 4 dr's with 255's <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=508831"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=508832"/> Next to 4 dr with TF BB and 285's <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=508833"/> Don't know if this helps, but it might give you another option. Read this as well. https://www.jk-forum.com/forums/modi...bie-has-18617/
The springs are the same length. You should look for rubi take offs. I'm running them with the tera flex puck style spacers and 19/59 rubi springs with 315 's <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=508861"/> I will be adding some flat fenders at the end of the winter and keeping the LCG look with the 35's
lift
2" lift is good, i have a 3" w/35's! very large. my mom has a hard time getting in i got her a step stool, but you should into what my boyfriend has, an automatic sidestep! when you open the door, it pops out, close the door and it goes back in, really neat, i wish i could afford it, i think it costs $2T? good luck. remember the higher you lift it you'll need to get the appropriate, longer driveshaft. good luck! --lindasjeep. in socal.
