Death wobble
Old Jan 8, 2014 | 08:02 PM
wally22's Avatar
Default Death wobble
Hi everyone... I'm new to this forum but I have a question and hope I'm posting on the right forum. I have had "death wobble" at high speeds 2 different times and it's getting worse. I had my alignment checked and it's not the alignment... So what's left? I thought maybe steering stabilizer but I don't think that will cause death wobble alone, but I could be wrong! Any advice and direction would be awesome!
Old Jan 8, 2014 | 08:05 PM
meep97's Avatar
Steering stabilizer won't cause DW
https://www.jk-forum.com/forums/jk-w...obbles-260145/
Old Jan 8, 2014 | 09:13 PM
AlexjeepVb's Avatar
Have you checked the balance on your tires recently? This is one of the most common reasons DW will start. Also the track bars being tight should be checked. Hope this helps.
Old Jan 8, 2014 | 09:20 PM
Croce's Avatar
As others said check the track bar. Should be torqued to 125ft lbs at both ends
Old Jan 18, 2014 | 06:22 AM
clarky84's Avatar
Steering damper is pretty common here for death wobble. Unbolt the bolt and the end of the ram. If you can move it easily by hand they will be your issue. At our dealer we've had a few with under inflated tires causing the wobble as well. Just a thought
Old Jan 18, 2014 | 06:47 AM
meep97's Avatar
These can cause DW, but is not the source of DW.
Old Jan 18, 2014 | 06:51 AM
planman's Avatar
Forum Tech Advisor
Reading is fundamental:
Heck, you don't even have to read. I made videos for people too lazy to read ;-)
Old Jan 18, 2014 | 06:52 AM
GIJK's Avatar
90% of the time it's the track bar bolts and or bushings. Try torquing first, if that doesn't work look for plan mans YouTube video. It is very frustrating not being able to drive your rig during the time it takes to diagnose the problem. If you need an immediate bandaid until you figure it out purchase the Fox ATS. This SS will stop a herd of elephants.
Old Jan 18, 2014 | 06:54 AM
ToolManTimTaylor's Avatar
Steering damper is pretty common here for death wobble. Just a thought
Not at all
Things like improper steering geometry after a lift , axle not being centered under vehicle properly with adjustable track bar or bracketry after a lift install , tie rod ends , ball joints , bad toe in / toe out adjustment
Old Jan 18, 2014 | 07:07 AM
JK Redneck's Avatar
have you checked your ball joints? I have an 07 and had to replace factory ones. They did not come with a grease fitting so ordered new ones with them.
