DEI 508D Proximity Motion Sensor addition to stock alarm system
#31
I need to do that. I actually cut that "thin wire" when I was just trying to strip it back a little to connect the switch for my ARB air compressor.
#32
Hey yomondo! Was there any room under or behind the center console insert? The back of all my switches (spot lights, rock lights and compressor) are where you mounted the sensor so I need to find a different location. Also I have a 4 door so I have to watch the rear window switches as well.
Do you think that the amount of stuff or type of stuff you have in the center console will affect the range and accuracy of the sensor?
Post 27 was having sensitivity problems, I wonder if they have a lot of metal (i.e. Mag light, coins, etc..) in the console if this could throw off the sensor. Or if you adjust the sensitivity then stuff either shifts around in the console while you or else if you take out / add stuff to your console if that would change your calibration enough to give the problems he is having.
#33
Sweet! I'm glad it worked for you! The awesome thing about Jeeps is customization and making something work for you. So I applaud your innovation and improvisation. And it's cool to see how others seem to be taking this and that and making something that works for them.
txjeeplover, thanks again for helping this write-up!
I installed my relay today (I'll update the initial post shortly). One thing I did differently, is that I put the relay inline with the (+) power source to the sensor, instead of inline with the trigger wire as you did. But either way will net the same resulting behavior.
#34
You have to play with the sensitivity and find a happy medium. It takes a bit of trial and error. You'll only get about 2-2.5 feet of radius. More than that, and you'll get false alarms from people walking by in a parking lot. And because of the rectangular shape of your 4-door, you won't get full front-to-back coverage (unless you install a second sensor!).
#35
My goal is just to help keep my MyGig from ever leaving the dash, with the fewest number of false alarms.
I had originally planned on using a shock sensor, but I'm intrigued by the motion sensor. Just worried that dialing it down so that it won't go off when people walk by in a crowded parking lot would cause it not to sense someone yanking around on the dash.
#36
#38
