DIY Rock Knob Shifter for Auto Trans
Old May 31, 2009 | 11:53 AM
landerley's Avatar
Default DIY Rock Knob Shifter for Auto Trans
I wanted to change up the interior of my Jeep by adding some Rock Knobs to the Auto Trans selector shifter and the transfer case shifter. But didn't want to pay $39.00 for each knob and $25.00 for the Auto Trans adapter from Lo-Dapt. So this is what I put together.
Parts:
2 Rocks (from yard)
JB Weld (in garage)
1/2"x8" galvanized pipe ( Home Depot (HD) $2.66)
3/8"x4" galvanized pipe ( HD $2.58)
1/2"x 1-1/2" Compression Spring (Part of a 4 pack pf springs HD $3.98 Part#759 796)
5/8" OD Lock Washer (in garage)
27/64" L, 29/64" OD x 324" ID 10 7 Nylon Spacer (HD $0.54, UPC #30699 872787)
2 x 4mm set screws ( in garage)
Step 1:
Cut the threaded ends of each pipe so that the 1/2" pipe was 4" long and 3/8" pipe was 3" long.
Used a 5/8" drill bit to ream out the 1/2" pipe, and then used a rat tail file to smooth out the insides of booth pipes.
Step 2:
Glued the pipes to the rocks using the JB Weld. Worked best by putting the JB Weld inside the pipes and then sitting the pipes on top of the rocks.
Step 3:
Drilled and tapped a 4mm set screw hole in the 3/8" pipe proximately 1" down from the rock.
Step 4:
On the 1/2" pipe; Cut a 3/16" (TYPO IN PHOTO) wide by 7/8" long slot starting 3/8" up from the bottom of the pipe. (I used a Roto Zip tool and file for this)
Step 5:
Painted the pipe fittings
Step 6:
Installed the washer, spacer and spring (see note 1) as shown and then installed the knobs.
You change gears by pressing down and then shifting, Rock On!
Note 1: The extra spring was needed due to the weight of the rock pushing down on the shifter release rod. The OEM spring that hold the release rod up could hold the rock up in Park but in Drive the Transmission wanted to slip into 2nd.
Name:	Rock Knob 1.jpg
ID:	24893   Click image for larger version
Name:	Rock Knob 2.jpg
ID:	24894   Click image for larger version
Name:	Rock Knob 2a.jpg
ID:	24895   Click image for larger version
Name:	Rock Knob 3.jpg
ID:	24896   Click image for larger version
Name:	Rock Knob 4.jpg
Old May 31, 2009 | 05:17 PM
Default sweet job
That is some good details & pics. Thanks for posting up. I need a bigger sheet of paper for all the mods I'd like to do... I've run out of room on the post-it in my wallet!
Old Jul 30, 2009 | 04:57 AM
Greenmachine's Avatar
Awesome job! I can't wait to do this one!
Old Jul 30, 2009 | 05:24 AM
ronjenx's Avatar
Clever!!
But I have to ask: are there holes in the floor for your feet to stick out?
This takes me back to the early '60s, Friday nights, at 8:30.
Old Jul 30, 2009 | 06:51 AM
JackMac4's Avatar
Originally Posted by landerley
Am I the only one that thinks it looks like you have a half-eaten cupcake and a mushroom top for shifters?
Just teasin ya - nice work on the DIY!
Old Aug 1, 2009 | 03:01 AM
JKdewd's Avatar
Default rock
This is neat.. like the rock look
Old Aug 1, 2009 | 05:27 PM
Did you have to tap the shifter shafts for the set screws? Looks Great! I like the rock looks as well!
Old Aug 19, 2009 | 12:04 PM
REDROBICON's Avatar
That's awesome
Old Aug 23, 2009 | 06:13 PM
woodweavil's Avatar
I have a complete set of mini pool balls. 1.5 dia. im thinking 8 ball shifter and que ball transfer. I have a whole set anyone interested in a particular number?
Old Aug 24, 2009 | 04:47 PM
woodweavil's Avatar
bump ............
