Front fender flare rework
For those of you that wheel in tight tree locations, You will know why i have done this due to the fender flare just taking a beating and tired of trying to get them back together.
What i did was remove the 3 Lb plastic substructure under the front fender flare and cut down the plastic wheel tub just enought to cover the engine areas. Also got new corner lights from Schucks on rubber mounting.
Now when i slide into a tree or rock the fender flare pops up and out of the clips or just breaks the clips only, which cost me 35 cents each.
