Front grill removal..... (help)
Old Aug 15, 2009 | 10:14 AM
adoornbosc's Avatar
Post Front grill removal..... (help)
Dose anyone have pictures with step by step on how to remove the front grill. I took off the 5 or 6 plastic rivets and pulled out the bottom. I see it's still being held by the turn signal bracket or somehting around the area. I don't want to brake anything. So I was hoping for some advice. I want to remove it because I want to apply Line x to it.
Old Aug 15, 2009 | 02:55 PM
pirate's Avatar
just put your hands right around the turn signal and pull on it, it has the same type of clips holding it in like the bottom does. the grill will flex quite a bit it feels like its made of plastic.
Old Aug 15, 2009 | 05:36 PM
8000ft's Avatar
yep it's plastic. a firm and smooth pull should do it.
Old Aug 15, 2009 | 09:13 PM
JK-Blue's Avatar
Just give it a pull. It'll come off.
Old Aug 15, 2009 | 09:18 PM
cyruspura's Avatar
Best answer. It should be very easy just go slow and smooth.
Old Aug 16, 2009 | 12:22 AM
aldaman's Avatar
Here's some instructions from a bodylift install...Refer to #1 and figures 2, 3 & 4...
Old Aug 16, 2009 | 08:20 AM
adoornbosc's Avatar
Default Thank You
Thanks you guys for your comments.
