Hard top one person removal
Old 04-10-2014, 06:31 PM
truckie515's Avatar
Like any project make sure that your top piece on your "gallows" allows you enough room to get between your jeep and the gallows. I have a thought about using my Boss Cart, to maybe modify my lifting bracket.
Old 04-11-2014, 04:59 AM
Tmjeep's Avatar
What kind and where did you get the orange hooks from?
Old 04-11-2014, 05:35 AM
truckie515's Avatar
The orange hooks were purchased at Home Depot. Don't remember the name got them where you find the hooks to hang stuff in work shop. Needed a 2 inch throat to make a good bite on the rear at the window. Think they cost under 5 each.
Old 04-11-2014, 07:03 PM
Tmjeep's Avatar
Thanks! I'll see if I can find them
Old 04-11-2014, 07:10 PM
Tmjeep's Avatar
Were these it?
40 lb. Small Steel J-Hook
http://thd.co/1550gxd
Old 04-12-2014, 03:37 AM
MTMxRubi's Avatar
Here is my first shot at a lift. Lower 2x4 will go under the furthest back bolt holes in the top. Plan to put a screw through the back holes in the top into the 2x4 (should keep it pretty secure). The front 2x4 has two rubber coated hooks to support the top near the rear doors.
ID:	545049   Click image for larger version
Old 04-12-2014, 04:04 AM
JayswranglerX's Avatar
Looks awesome!
Sent from my LG-LS980 using JK-Forum
Old 04-12-2014, 05:25 AM
MTMxRubi's Avatar
Originally Posted by JayswranglerX
Looks awesome! Sent from my LG-LS980 using JK-Forum
Thanks. I'll see how it works later today.
Old 04-12-2014, 05:06 PM
MTMxRubi's Avatar
Thanks. I'll see how it works later today. Sent from my iPhone using JK-Forum
My home made lift worked great. Ended up adding an extra set of pulleys to make the lift easier.
ID:	545199   Click image for larger version
ID:	545200   Click image for larger version
ID:	545201   Click image for larger version
ID:	545202   Click image for larger version
Old 04-12-2014, 05:24 PM
truckie515's Avatar
That's the nice thing about pulleys the more you add the less work, the down side more pulleys more rope needs to be pulled. I very seldom go any more then a 3:1. The wench I am using is already 3:1 so no real work used to lift it.
Quick Reply: Hard top one person removal
