Hardtop Thumbscrews
Old Nov 1, 2009 | 05:56 AM
earnsdorff's Avatar
Default Hardtop Thumbscrews
This is a very simple modification but wanted to share it. I suspect others have done similar things and I couldn't find any posts in the forum so forgive me if this has been posted before.
I changed the 6 Torx bolts that secure the hardtop on my 2-door '07 JK with 6 thumbscrews. This makes taking off the hardtop much simpler.
This is a pic of the actual thumbscrew:
I purchased the thumbscrews from MSC Direct. Below is the bag showing the manufacturer and size (M8x30 mm)
This along with my new lift allows me to remove or install my top in approximately 5 minutes.
Just in time for winter
I have had this installed now for about a month and have removed/installed my hardtop several times - it works great.
Old Nov 1, 2009 | 07:41 AM
Limpoe's Avatar
Very nice idea!! I'll take it! Thanks
Old Nov 1, 2009 | 07:12 PM
BullandTerrier's Avatar
I couldn't find metric thumb screws anythere. I had to settle with hex bolts. Good work.
Old Nov 1, 2009 | 07:14 PM
Sweet idea! This is going on my list.
Old Nov 1, 2009 | 07:52 PM
ratherbskiing3's Avatar
Count me in
here is the link
http://www1.mscdirect.com/CGI/GSDRVSM?PACACHE=000000114458558
Last edited by Robar; Nov 8, 2009 at 06:38 AM. Reason: PLEASE DO NOT POST CLICKABLE NON SPONSOR LINKS
horwitzs's Avatar
Costs more than a hardware store, but if you can't find them locally you can also order these:
www.quadratec.com/products/13122_1000.htm
Old Nov 1, 2009 | 10:17 PM
xerofall's Avatar
^^^ Quadratec is a sponsor, so you can post links. I got mine off eBay... they are soooo nice, I'm glad I bought them.
Old Nov 2, 2009 | 10:52 AM
horwitzs's Avatar
Ah OK, I fixed it. I always post my links that way unless I am absolutely sure it's ok.
Old Nov 3, 2009 | 12:25 PM
robin's Avatar
good idea!!!!!
Old Nov 3, 2009 | 03:04 PM
earnsdorff's Avatar
I wasn't sure if this was obvious or not. I'm glad it helped out a little.
FYI: The MSC Direct part number is 82054685. The total cost for 6 was under $20 but that was with a discount through my company. It is a little over $20 for the listed cost. Either way a fairly inexpensive upgrade. But I don't understand why Jeep wouldn't have thought to make these easier to remove.
