HID Headlight Kit Install
Old Jul 16, 2009 | 05:49 AM
GregD's Avatar
Originally Posted by tprice1985
Greg that looks great. I am about to order today. i do wnat to ask one other questin...the cutoff looks very sharp, does it prevent lighting any or doe the lights still light EVERYTHING up?
The cutoff is virtually identical to the stock headlights, which makes sense since the reflectors are the same. It's probably necessary to not blind opposing traffic. The cutoff on the bottom doesn't really matter since it's relatively close to the vehicle, and if you turn on the fog lights, the lower portion gets almost completely filled in on the road.
I don't have pictures yet, but the high beams don't have the same cutoff, and light up and down a lot more.
Old Jul 16, 2009 | 09:33 PM
GregD's Avatar
Default High beam pictures
High Beams. These were taken from approximately the same location as the low beam shots in the prior post.
ID:	27090   Click image for larger version
Old Jul 21, 2009 | 11:23 AM
JPTwinz's Avatar
Here is what the warning light canceller looks like from VVME. This unit is just plug and play between the stock wiring and the ballasts and will eliminate the flicker when the engine is running.
Old Jul 24, 2009 | 09:29 AM
JPTwinz's Avatar
GregD, what Kelvin temp were your HIDs (3000k, 4500k, 6000k....)?
Old Jul 24, 2009 | 09:51 AM
GregD's Avatar
I went with the 4300K kit since it has the highest light output.
Old Mar 23, 2010 | 09:36 PM
1star2's Avatar
Very good write up, I've been wanting to do this to my wife's Jeep.
Old Mar 29, 2010 | 10:40 AM
ThaVisionary's Avatar
I purchased some HID's recently from sharphid.com they were reasonable at $100 and they made a huge difference on night driving.
I am looking to get new fog lamps as well, does anyone have any suggestions?
Old Jul 6, 2010 | 06:23 PM
Slightlymodified's Avatar
The warning light cancellers do not work for the relay's buzzing or the headlights flickering. The only thing that works so far is using a capacitor and diode in the relay harness coming from the headlight signal plug. I bought the warning light cancellers and put them in, but they did NOTHING. Just a heads up to anyone else doing this install. Don't waste your money on them.
Old Jul 30, 2010 | 01:04 AM
jeepnyak's Avatar
Well that sucks, I just ordered these with my kit.
Old May 15, 2011 | 01:04 PM
SIDsjeep's Avatar
Veteran: Coast Guard
ok this thread is awesome and very informative, just got lost at this step what and where do you get this diod and capacitor at and how do you mount it sorry for the dumb question i guess im a noob when it comes to these things and did it come with the kit?
