Hood Latches!
Old Dec 12, 2012 | 02:56 PM
  #41
Gman*2007's Avatar
Originally Posted by 12HTownSahara
Daystar good wranglers. Best 20 bucks you will spend.
10-4 on the Daystar hood wranglers. Totally does away with all hood fludder, they are tight.
Old Apr 14, 2013 | 04:04 AM
  #42
MikekiM's Avatar
My take on this mod...
I had wanted to do this for a long time, but never got around to it. Plus I had a set of Rampage locking latches so hood flutter wasn't an issue any longer. Being in the NE, all stainless was the only way to go, but the parts always ended up costing way more than I wanted to spend. Then I stumbled over a set of Race Grade fiberglass reinforced nylon rod ends with PTFE balls.. perfect! Crazy strong, light weight, black..
If you're reading this, you probably aren't interested in a set of Rampage locking latches, but mine are now in the For Sale forum...
Old Apr 14, 2013 | 06:48 AM
  #43
lube09's Avatar
I plasti dipped mine and they turned out great. My issue is the lower bolts I used are starting to rust. Wondering what others used for the lower bolts. Mine were black oxide but now are more burnt orange (rusty).
Old Apr 14, 2013 | 08:46 AM
  #44
CharlesS's Avatar
Originally Posted by B09RUBI
you can see that I started drilling while the mounts were installed (jacked up paint)but found out drill bits were to short so i removed the mounts to drill
What happened to you was what I was afraid of or worse.... so before I started drilling out the pins I applied several strips of duct tape around the mounts to protect the surface. I would have to REALLY mess up to damage the surface.
Old Apr 14, 2013 | 04:40 PM
  #45
MikekiM's Avatar
Why wouldn't you use stainless bolts?
Old Apr 14, 2013 | 05:04 PM
  #46
lube09's Avatar
I wanted them black.
Old Apr 17, 2013 | 05:17 PM
  #47
MikekiM's Avatar
Bedline the stainless...
Old Apr 18, 2013 | 11:00 AM
  #48
JKJA10's Avatar
I installed the xhd hood catches from Rugged Ridge.
Old Apr 19, 2013 | 01:07 PM
  #49
HankFard's Avatar
Black oxide is not always effective as an anti-corrosion treatment. Depends on whether it was applied at high temperature (for protection) or cold temperature (cosmetic).
Old Apr 21, 2013 | 03:19 PM
  #50
16 Unlimited Ways's Avatar
Got the Rampage hood locks a few weeks back...AEV hood and all...Tight fit look good...
