I phone holder?
Old Sep 27, 2013 | 11:22 AM
crayne's Avatar
Default I phone holder?
Anyone make a dash or any type holder for a phone that works on a JK?
Old Sep 28, 2013 | 04:54 AM
Shearlow's Avatar
I have the bracketron mount with the bracket that fits between the side of the radio and the dash (bolt-in), I got it from Q-tec, it works pretty well.
Old Sep 28, 2013 | 04:57 AM
darkknight1999's Avatar
I made my own bracket and use a Rokform case. Works perfect... Only took about 2 hours to make.
I made the bracket out of scrap aluminum I had (cut and shaped the aluminum with a Dremel), bent it to match the contour of the dash, painted and textured to match the dash and picked up the allen bolts and washers at the hardware store for $4 bucks. Once it was ready I mounted the Rokform mount to the bracket. Once it was ready I riveted the bracket to the dash. The Jeep could roll over and its not coming off
This is the case I use.
http://www.rokform.com/rokshield-v3-ip5/
Old Sep 28, 2013 | 07:11 AM
lkinmond's Avatar
Depending on what year you have, this solution might work for you - I love it.
https://www.jk-forum.com/forums/modi...lution-286186/
Old Sep 28, 2013 | 07:51 AM
The other location that this could be mounted to is right above the review mirror. Same design just upside down. You could also build a bracket and mount and attach it to the review mirror itself.
Old Sep 29, 2013 | 03:14 PM
drexelsteve's Avatar
Rokform case with the magnetic pad option and a panavise radio mount!!!
Old Sep 29, 2013 | 03:21 PM
I have the magnet pad on my phone, it will fall off when you go rough wheeling. I use these in all my cars. The magnet is very strong but not strong enough to trust it during wheeling... It will slide around and sooner or later fall off.
Old Sep 29, 2013 | 03:49 PM
tcdawg's Avatar
Good stuff here:
http://www.rammount.com/
Old Sep 30, 2013 | 06:39 AM
TH3APPL3GUY's Avatar
I have a RAM suction cup mount for my iPhone and I would not recommend any other mount, the RAM mount is hands down the best iPhone mounting solution that I have found for my JK.
Old Dec 6, 2013 | 06:39 PM
Dbathke's Avatar
Default Smittybuilt has a great phone holder
I picked one up at my local 4 wheel parts store. 25.00 I believe, it works amazingly well.
