An Improved Grab Handle Solution
Old Mar 23, 2007 | 08:10 PM
  #31
JeepCacher's Avatar
Originally Posted by bleblanc
I've got the Mastercraft grab handles and these ones look identical. I put in an order yesterday, so we will have to wait and see.
Ordered mine Tuesday. Got em today and put em on. I've got the red Mastercrafts up front and they are identical.
It's also the same handle that's on my laptop case....these things get around.
Old Mar 23, 2007 | 10:50 PM
  #32
Rubimon's Avatar
Okay, handles came in two days flat. That is faster than some woman I know! (Just kidding, bad joke!) Like the post above, I went and checked my laptop case, BAM! perfect match too. So I went to put my straps on, got out my Bosch cordless drill, BAM! perfect match again. Someone is cranking these things out!
[IMG][/IMG]
Like I said, I did the grommet thing, works great, no worries about fraying edges. Used the washer underneath too!
[IMG][/IMG]
Great mod German, good find on the handles, farbuckle! These handles look like they came stock on the Jeep!
Finished Product
[IMG][/IMG]
Should have my matching Mastercraft handles on Monday or Tuesday.
Old Mar 27, 2007 | 09:22 AM
  #33
ksroqclimber's Avatar
where did you get your gromet tool?
Old Mar 27, 2007 | 10:37 AM
  #34
Rubimon's Avatar
Home Depot...Tool section, they are only a couple of bucks...I have a few different sizes. They are handy to have around the house.
Old Mar 27, 2007 | 01:01 PM
  #35
superboo's Avatar
wanna do a grommet installation writeup?
Old Mar 28, 2007 | 10:34 AM
  #36
LT1-YJ's Avatar
Found the same ones for the front online at jd's. They are OMIX / Rugged Ridge.
Just got an email back from Omix and they said they will be offering a handle setup for the rear like that.
"Thanks for the heads up. We have already produced these items and they are on there way to us now. The following images are of the center dual grab handle, the front seat headrest grab handles and the rear roll bar grab handles for the JK…. Stock should be in very soon.
Both the rear grab handles and the dual center have metal eyelets pressed on so the customer only needs to unscrew the bolts to install. The head rest grab handles only require that the customer remove the head rest and then reinstall. "
I got the PDF for install which has pics if anyone wants to check it out.
Old Mar 28, 2007 | 12:56 PM
  #37
duneslider's Avatar
Are the handles for the front doors the 2" or 3" straps? Now that I have a lift the wife says we have to get handles. I guess that is a good trade.
Bryan
Old Mar 28, 2007 | 01:28 PM
  #38
Rubimon's Avatar
Bryan
I ordered the 3 inch as that seems to be the diameter of the bar and padding. I will know soon.
Old Mar 28, 2007 | 03:15 PM
  #39
bleblanc's Avatar
I ordered the 2" and it is REALLLY tight ,but it does do the job.
Old Mar 28, 2007 | 03:47 PM
  #40
LT1-YJ's Avatar
the omix / rugged ridge ones dont specify a size cause they have enough adjustment for the larger rollbars. I used them in the front on my JK and they worked fine.
