Installation PIAA lights
Old May 28, 2011 | 07:44 AM
Mikey214's Avatar
Default Installation PIAA lights
Where do I hook up the wire for the led light on my switch ? It says a power source but where ?
Old May 28, 2011 | 08:04 AM
JK-Ford's Avatar
Depends. If the LED isolated from the switch power, then connect it to the dimmer circuit behind the HVAC panel. If the LED is activated by the switch power, then you only need to ground the switch.
Old May 28, 2011 | 08:09 AM
Mikey214's Avatar
The led wire comes off the switch and the directions say to connect it to a power source . . .
