Kilby JK cargo panels
Old Jan 31, 2010 | 04:00 PM
X-caiver's Avatar
Default Kilby JK cargo panels
To facilitate future mods, I installed a set of Kilby Enterprises JK cargo panels. These are basically two pieces of bent sheet metal cut to fit.
They don't actually do anything at all. So what's the point? The point is that they give you a nice surface to mount things on.
Read on for install pics.
One of the pictures on the Kilby website shows a couple of 12v power sockets mounted in them, and that's what I intend to use them for. I'll mount a couple of 12v sockets (aka 'cigaratte lighter things'), as well some 120v power outlets (there is room behind the panels to hide a dismantled inverter), and some mounting hooks.
The panels came in a big box, wrapped up in paper to keep them from getting scratched up.
http://www.flickr.com/photos/donpattee/4319908769/
Also got a bag of 6 t-handle bolts to replace the hex-head bolts that came with the hard top.
_4d012570b6.jpg[/img][/ame]
Before pic.
[ame="http://www.flickr.com/photos/donpattee/4320642512/
The 3 holes on each side are where the hard top normally mounts. These panels are thin enough that the hard top can still be installed just fine.
"http://www.flickr.com/photos/donpattee/4319908971/"
The panel has cut outs and the front and back to fit around the soft top plastic mounting pieces also.
"http://www.flickr.com/photos/donpattee/4320642654/"
If the front of your panel interferes with the plastic door surround (used when you are running the soft top) you have an early production version, and need to contact Kilby.
"http://www.flickr.com/photos/donpattee/4319909217/"
Here you can see the difference between an early (front) and current (rear) panel. The early panel works with hard tops only, the current design has a larger cut-out in the front which lets it work with the soft top plastic rear door frame.
"http://www.flickr.com/photos/donpattee/4319909295/"
Their logo is nicely done, looks like laser cut metal, but I'd rather make use of the holes.
"http://www.flickr.com/photos/donpattee/4320642972/"
I bought 4 lifting eye bolts off eBay. Neither Home Depot nor Amazon didn't have any short enough to keep them from rubbing against the carpet. The threading is 1/4-20, and on these the bolt part is about a half-inch long, with a 1 inch eye.
"http://www.flickr.com/photos/donpattee/4320643136/"
"http://www.flickr.com/photos/donpattee/4320643242/"
Mounted, with flat elastic bungee cord handing from the eyelets.
"http://www.flickr.com/photos/donpattee/4319909793/"
Last edited by toad; Feb 1, 2010 at 09:48 AM. Reason: Please no clickable links to non-sponsors. Thanks!
Old Feb 1, 2010 | 06:49 AM
Skippman's Avatar
I like these but I don't know if I'll end up with them because I don't think they're compatable with the heavy duty MPAC rack.
Old Feb 1, 2010 | 07:27 AM
noot's Avatar
Can you store stuff under/in them? I wanted to make something similar out of wood, with openable panels on the top so I could store smaller stuff.
Old Feb 1, 2010 | 09:23 AM
X-caiver's Avatar
You wouldn't run one of these on the same side that you had an MPAC rack. But, since the MPAC units seem to be sold individually, you could run one on one side, and one Kilby panel on the other side for your power outlets.
The bolt holes on the top of the Kilby aren't actually holes, they are 'U' cut-outs. So if you wanted to strap something heavy down there is the possibility that you could slowly slide the kilby panel out. I'm not sure how likely that is, maybe if you were using a ratcheting strap from one side to the other you might accidentally do it.
The MPAC uses actual 'holes' on the top, plus they mount down at the bottom also, so they aren't going to move.
To the other question - no, you can't store random things behind the Kilby panels. Well, you could, but it would be a pain every time you wanted to get to your stuff.
Old Feb 1, 2010 | 08:55 PM
sickchilly's Avatar
I love the idea of these things. I wish they would have made them a bit wider though. I wanted to mount a Viair 450C inside each one.
https://www.jk-forum.com/forums/show...98#post1509098
