LED Brake and Backup Lights
Too bad the ECU causes the fast-flash. I guess there's a law that states that flashers need to indicate a bulb failure (hence the fast-flash), but with LEDs there is SOME current flow, not NONE (none indicates a failure). The ECU must use a current threshold rather than a "yes/no" current check, which is really too bad.
js.
. The issue here is that the JK doesn' have a dedicated flasher unit, it's built into the ECU, thus it's not as simple as replacing the flasher.
