Led map lights.
Old Jan 25, 2013 | 07:39 PM
rynokid's Avatar
Originally Posted by xerofall
What type of adhesive did you use?
I've used two different types and in the heat if summer, nothing will stay adhered to those panels, :( for me anyway... so be careful they don't just randomly fall on your head.
Thanks! I just used the double sided tape that came with it. If it falls it's just one of those things I guess. Luckily it doesn't get too hot here in San Diego. I can see it now landing on my head when I'm on a trail. Haha. Makes me laugh.
Old Jan 25, 2013 | 11:22 PM
xerofall's Avatar
I've tried industrial velcro and Gorilla Glue and nada... might try Liquid Nails.
Old Jan 26, 2013 | 01:01 PM
rynokid's Avatar
Did you hit the top with some sandpaper first? Not too much just enough to rough it up a bit?
Old Jan 26, 2013 | 08:59 PM
xerofall's Avatar
Yeah, I have... but I deal with a lot more heat than San Diego, haha, I may try something more drastic.
I'm talking about custom heat reducing panels, not LED lights, so they are also a bit more weight. You may never have problems, just a heads up.
Old Jan 27, 2013 | 08:53 AM
rynokid's Avatar
Good luck man! Where are you at that its so hot?
Old Jan 27, 2013 | 10:37 AM
loserhead4236's Avatar
I found some really similar lights at wally world for my trunk enclosure I just built. Im not sure about your lights, but mine have 2 holes where the sticky side would go. They are the sliding holes that you can hook up to screws. I drilled 2 screws into my trunk and now I am able to mount the light onto the screws and then slide the light down to lock it into place.
Old Jan 27, 2013 | 08:56 PM
xerofall's Avatar
West Utah desert. I was at Ikea today with the wife and showed her what you did, she likes them and wants me to do it once I get those panels secured.
Old Jan 27, 2013 | 09:23 PM
jeepmojo's Avatar
Default - 20 degees in nh might kill the batteries
id like to try a set just the same hell 6 bucks you cant beat it every time im in the back doin something for a long time the lights go out ! have to close the door reopen just to get the frican light back on . these would allieviate that problem!
Old Jan 28, 2013 | 12:32 AM
GCONDA's Avatar
So awesome. Not I won't feel bad disabling the map lights in my mirror. Then I can put the led bulb in the rear
Old Jan 28, 2013 | 08:13 PM
rynokid's Avatar
I put a set in the back as well. Love the price. If it doesn't work out you're not out a ton. Plus the light out out is surprisingly a lot.
