Manual Swaybar Disconnect (non-Rubicon models)
If you've got any lift or are not sure, test with a buddy. Disconnect and have one of your front wheels climp something, check the flex on the other wheel to see. It seems that 1" or so you're still fine, approaching 2" a full flex puts your lines in jeopardy.
If you're stock you'll be fine, they're made for that.
Here they are connected:
Here is the clevis pin match welded to the frame:
Here are some photos of the sway bar when disconnected and pinned out of the way:
I just used hair pin cotter pins, clevis pins (2/5" x 7/16) and washers.
