My Heated Seats- Toasty Buns!!
Old 10-30-2007, 04:29 AM
  #41
tcpatter's Avatar
Originally Posted by CarFanatic
ya, I ordered from the same site, and ordered the mini pin fuse with the lead. So it under the hood... ok was hoping there was a spot inside. You powered both seats off the same power?
When I ordered the kit, it came with one wiring harness that ran both seats. So you only need to hook up the power once.
Old 10-30-2007, 05:24 AM
  #42
CarFanatic's Avatar
ah great!
MY X doesn't have those airbag sensors??
Old 10-31-2007, 05:19 PM
  #43
CarFanatic's Avatar
I got my heated seats today. One question It says to remove the protective backing or it can be a fire hazard. All I have is two white strips at each end. is this what they are talking about? Also it came with duct tape lookin strips. I peeled back the white strips on the elements but there not stickey. so how do you secure it to the seat?
Old 10-31-2007, 06:16 PM
  #44
awfrode's Avatar
Great tech write up & pics. Thanks
Old 11-01-2007, 12:01 PM
  #45
DBB888's Avatar
The white tape is double sided tape. Peel carefully
Old 11-01-2007, 12:03 PM
  #46
DBB888's Avatar
Yes- only one power source
Old 11-01-2007, 12:48 PM
  #47
CarFanatic's Avatar
only the one strip has to be double sided. is this correct? If not this is some THIN double sided tape! Do you use the duct tape strips aswell?
If some one could post how they attached them to the seats that be great. The directions are kinda wack. Talking about drilling holes and stuff. last thing I want is to set my butt on fire!
Old 11-01-2007, 03:33 PM
  #48
CarFanatic's Avatar
ok I looked closer at it. The double sided tape is clear. So it is quite thin. So I just going to peel them off and stick to the seat. Then use the other tape around the edges of the pad. This correct?
Old 11-01-2007, 04:39 PM
  #49
billycj7's Avatar
yeah, that should work great. make sure that you push it a little bit into the crevices that run front to back and top to bottom on the seat foam so that the fabric will sit correctly when you re-install.
Old 11-02-2007, 05:18 AM
  #50
CarFanatic's Avatar
ok so tuck it into the slits in the foam. I can do that!
Quick Reply: My Heated Seats- Toasty Buns!!
