My Insulated Headliner Project
Yeah, that is my biggest question, is how long it will stay up. So far the freedom tops are holding, a week thus.
With the material I used, it would not be hard to do the side of the hard top. The hardest part would be making the edges look good/consistent when putting the liner on the insulated sheeting. This would also reduce the echo even more, and make the radio sound better...
That looks great man... I have been planning on just bedlining the inside of the hard top at some point this summer while I have the soft top on (the white looks horrible and I dont know what they were thinking). But after seeing how well yours turned out I think I might have to insulate it while I am at it and see if it will help during the cold winters too.
I am amazed at the difference this makes, and am happy though tired, that I did it
For the OP:
Do you have Sirius? If you do did it effect the reception at all?
All of these hardtop insulation ideas are great! I'm trying to learn as much as possible before tackling it.
Thanks!
Thanks!
Yes I do have Sirius, and yes it did block the reception
But not to worry, you can go get a Sirius car install kit for the external antenna and route it to wherever you want. I installed mine on my hood in line with the washer sprayer. Better reception than the stock location. Reference this thread for where to connect: https://www.jk-forum.com/forums/jk-electrical-lighting-sound-systems-13/sirius-reception-fix-88145/
Yeah I was thinking about it. I recently commented on someone else's thread where they had the liner brought down the side, it looked really good. Perhaps a project for the future, yall done put me into the poor house, Im still spending
Found it, Here's the other thread: https://www.jk-forum.com/forums/jk-show-tell-33/new-rock-sliders-insulated-hard-top-92815/
Thanks,
Found it, Here's the other thread: https://www.jk-forum.com/forums/showthread.php?t=92815
I'd be interested how they stay up in the future or whether they sag or fall down.
Dang, the Sirius things a setback. I wondered about that when I saw the reflective aluminum foil type material on there. Wonder if I could make an area over the antenna that's not covered by that, but maybe by some foam padding instead to keep the texture the same.
