NEW Rigid Industries SR-M Flush Mount Back Up Light Kit
Old Oct 30, 2013 | 01:58 PM
Offroad_Elements's Avatar
Former Vendor
Default NEW Rigid Industries SR-M Flush Mount Back Up Light Kit
*A disclaimer before going any further. I am not a professional mechanic. These steps worked for me and are only meant as a guide.
I am extremely impressed with this kit and decided to do a quick write up from my experience last night.
Rigid Industries SR-M Back Up Kit | Offroad Elements
If you're interested in following the way I did this, I will gladly send along some Posi-Tap connectors with your order.
Tools:
Philips head screw driver
Dremel Tool
Allen Keys
Drill & 7/32” Drill Bit
Wire Cutters / Strippers
Wire Connectors
Remove factory tail light with a Philips head screw driver. Place SR-M gasket over the clear lens as a guide for cutting.
Fit the light and mark holes. Use 7/32” drill bit to make pilot holes. The ¼” bolts provided will tap into these quite easily.
I only wanted to tap these into the existing factory wiring, so I cut the harness it came with.
I used Posi-Tap connectors to on the end of the newly cut harness.
Connect new harness connects to old factory reverse light harness - positive to positive, negative to negative. Wrap up/waterproof old plug, and bundle everything together with electrical tape to avoid rattles.
Test to make sure it lights up. Re-install and that’s it!
The output is incredible, I look forward to backing up now.
Old Oct 30, 2013 | 02:31 PM
brikino's Avatar
Thanks for the write up! Seems simple and very effective. Any issues with the CANBUS not liking the SR-M's?
P.S. Like how you went with a Halloween theme on the Jeep with the skeleton.
Old Oct 30, 2013 | 05:35 PM
DesertJeep's Avatar
That's a great idea. Thanks for the write-up.
Old Oct 30, 2013 | 05:44 PM
TJM12's Avatar
Great idea!
Old Oct 30, 2013 | 05:52 PM
DesertJeep's Avatar
Do the SR-Ms come with gaskets to make a watertight seal? If not, what did you do to seal the join?
Old Oct 30, 2013 | 05:54 PM
Former Vendor
No issues with the electrical system after this install.
Old Oct 30, 2013 | 05:56 PM
Former Vendor
They do come with a rubber gasket. Shown in first photo.
Old Oct 30, 2013 | 06:33 PM
rodi's Avatar
ah this is great. need to order a set.
Old Oct 30, 2013 | 07:07 PM
nvglockster's Avatar
Thanks for the write-up!
Old Oct 31, 2013 | 04:18 AM
red09's Avatar
great write up. Been looking at a solution for the poor lighting back there and this seems to be it.
Hook those into an Spod and you can use them for trail work lights if needed.
