NV-241 / NV-241OR Transfer Case Service Write-Up
As a good part of routine maintenance on your Jeep JK Wrangler, it is highly recommended that you service your NV241 or NV241OR transfer case once every 30,000 miles. Changing out the ATF+4 transfer case fluid will give you an opportunity to inspect it for any signs of abnormal wear going on inside (i.e. bits of metal coming out) and new fluid will help keep things operating smoothly.
This is a very simple task and can be done in minutes with the right tools. Also, any ATF+4 fluid can be used. Click on the link below to see my write-up:
