OBD P0944 Only!! Don't Freak Out Yet...
SO I dropped the trans pan, replaced the filter, Did the Trans line flush, Added a B/M Super cooler, Bought the OBD Blue Tooth Reader for Android, Ran a Fault check and popped up P0944.
Hunted down the threads for what to do.... Found it goes into test mode most likely because I did the trans hose flush. Filling the fluid a little at a time and seeing it to my eyes filled correctly. Checking fluid and codes over and over and over... Well I think I it corrected as this morning no P0944 came up. Fault free....
Check fluid at 70 F, and it was correctly filled!
If you do this process you may pop P0944 if you do! take your time to make sure fluid is correct and let the Prime come back to the pump.
Again its some sort of test mode and low or over filled fluid is on the list of possible reasons.
Hope this helps calm someone...
