Off-road cargo tray
Old May 9, 2014 | 08:40 PM
Matthewd5's Avatar
Default Off-road cargo tray
First off, 99% of the credit for this goes to JK Forum member grimmjpr!
He had posted some photos of his cargo shelf and then I pm'ed him and asked a couple dozen questions about how he built his...
Then I sketched up my take on his concept just customized for my purposes.
And then once I had all of the core pieces, I enlisted the help,of a good friend of mine who is an artist, a commercial artist, and an amazing creator/fabricator of things that only he could have.
We used a piece of Baltic birch 1/2" plywood for its beautiful finish, it's light weight, and mostly because I had a spare sheet of it in my basement!
it comes in sheets 60"x60"
I can't post pictures right now as we are traveling and the hotel wifi sucks... I'll go through later and edit/add photo bucket links...
So I had some companies giant tray for the back of a 2 door JK to catch mud and sand
We put this upside down and traced the outline, we did multiple test fits and trimmed until it fit like a glove, actually it followed every curve without touching or rubbing anywhere
Then we built supports by measuring all of the different levels so the cargo tie down shelf would be nearly perfectly square
At the back of the shelf we added a wall and side braces to keep things separate between the cargo shelf and the space on the floor behind the two front seats in a two door... No rear seats were harmed, it's just been on two milk cartons since the day I brought this Jeep home from the dealership.
A LOT of detail went into this, every piece was glued and screwed, all square edges (minus the butt edges for joinery) were hit with a 1/4" router bit and then hand sanded...
Not just the top half but the supporting pillars and the underside of the shelf!
This is what happens when an ex-amateur cabinetmaker gets anal retentive about minute details
I chose the Core Trax 1000 system, someone on here first posted pictures and I looked into it and ordered a set that night! I believe it was Ron the JK Jedi from Maine!
I'm still playing with the locations of the tie down Trax but once that's solid I'll be painting or staining it all black.
I had a chance to test the new setup today and it worked great! everything stayed in place, no surprises.
I've got some ideas about rearranging the Core Trax so I can maximize both storage and improve access to the often used gear vs. the obscure rescue/trailside repair kit...
Matthew
Old May 10, 2014 | 02:13 PM
Blacksahara2011's Avatar
Can't wait to see some pictures. As a carpenter myself, I've been looking forward to tackling this project as soon as I get some free time. I've been drawing up a few things of my own but can't wait to see what you've come up with!!
Old May 10, 2014 | 06:30 PM
Matthewd5's Avatar
I'm home and I edited the original post and added a bunch of photos, please share comments and input, right now its not laid out in as efficient as it can/will be, once i rearrange the Trax and i'm going to modify how I pack my gear, I used to pack my gear into really large Pelican like cases...
The reason i'm moving to smaller bags is just the simplicity of getting to the piece of gear more quickly.
matthew
Old May 11, 2014 | 12:59 PM
Grimmjpr's Avatar
I was glad to help, yours came out sweet. I'm sure you'll change it up a bit as you see what you need and how to lay it out better. Nice job
Old May 11, 2014 | 01:34 PM
Matthewd5's Avatar
Originally Posted by Grimmjpr
I was glad to help, yours came out sweet. I'm sure you'll change it up a bit as you see what you need. Nice job
Thank you...your input was what r got me to build something that I had a rough outline in my head
The J hooks were a huge missing piece that works great, but I'm trying to make both short the end that's sticking up, and find a way to make them easier to install and to remove....
With them at the current length it's wasting space
Matthew
Old May 11, 2014 | 01:37 PM
simpleman909's Avatar
I was considering making a drawer type piece in mine. I like what you have going.
You better watch where you're going and remember where you been.
Old May 11, 2014 | 02:24 PM
Matthewd5's Avatar
Yeah a drawer would be a nice feature, But I think we have less 3" of space under there...
We put in a good bit of time making those vertical pieces are custom cut to make the whole piece level.
Originally my Yeti cooler was to be on the left side, and on a piece of plywood with a small set of the Core Trax to hold it down, and it would be on a heavy duty underneath drawer slider...
This would have let 3/4 of the cooler able to slide out so you could grab food and beverage on the trail!
But that piece of real estate was deemed more valuable for gear, with the cooler setup right against the back of the front seats...
Now you can just turn around and pop open the Yeti.
On each side of the Yeti, that space is for less urgent stuff like a container full of spare fluids and weird rescue stuff like duct tape, f4 tape, tons of zip ties etc.
I'm going to rearrange some things and I'll be adding a handful of the Core Trax short Trax for randomly places to maximize space.
Eventually I'll paint it all black to blend in with the black carpet
Matthew
Old May 13, 2014 | 08:54 AM
Vladimer's Avatar
Looks good! Couple questions if you don't mind.
How is the whole tray secured to the Jeep itself?
And is there a reason you went with about 3 inches clearance? Seems too small to be useful but could of made it lower to get a couple extra vertical inches?
Old May 13, 2014 | 10:21 AM
Matthewd5's Avatar
Great questions, I love questions because if I hadn't sent a barrage of questions and pm's to grim jeeper about his cargo platform, this one would have either been junk or not built at all...
The connection to the Jeep (talking two door here without the back seat) are hooks from a hardware store, I don't have a picture, but my local small hardware store only had round ends...
But the had me show them how much I needed and they proceeded to use a bolt cutter in the back room and then used the key making machines buffer to make it smooth.
Then you just carefully locate where the four loops are and drill the appropriate size hole, put the j hook threaded side up through the hole
Once you hook the loops put on washers and nuts with the nylon collar
The 3 inches was to level out the whole space
Matthew
Old May 15, 2014 | 03:38 PM
Matthewd5's Avatar
I was thinking about what you said, my version could easily be modified to make a drawer doable...
use thicker wood, 3/4", put in fewer spacers underneath, space them for the width do what you want your drawers width to be.
And more importantly, please takes turns of what you did, and if you need more info or more pictures just let me know!
matthew
