Rear Power Outlet Install
Old Jan 1, 2011 | 05:31 PM
Vic Hammer's Avatar
Wow, exactly where the 2011's have them factory installed. Looks great man!
Old Jan 1, 2011 | 05:35 PM
PhxRainey's Avatar
Default I like
I like it...looks like there is enough room for a 110 inverter in there?
Old Jan 2, 2011 | 09:12 AM
blndspt's Avatar
Did it impact the sound of the sub?
Old Jan 30, 2011 | 06:01 PM
Now that is totally and completely awesome
Old Jan 30, 2011 | 06:08 PM
husker_fan's Avatar
What size of fuse did you use inline?
Old Jan 31, 2011 | 05:23 AM
RedJK2's Avatar
I love it when people resurrect older threads, otherwise I wouldn't have come across this (since I'm new). Great mod!
Old Jan 31, 2011 | 06:55 AM
JKRVEE's Avatar
Funny, I did that 12v plug this weekend too. I just put mine up at the front top corner for easier access when I have stuff back there.
Old Jan 31, 2011 | 07:25 AM
husker_fan's Avatar
Did you wire yours up in the same way?
I am wondering if there is an easier way than all straight up to the battery, if there is a hot wire near the back to tap into.
Old Jan 31, 2011 | 03:49 PM
hotdogging's Avatar
Electrical newb here. Can the outlet be hooked up with an inline fuse then straight to the battery?
Old Jan 31, 2011 | 04:23 PM
ronjenx's Avatar
Any time you run a wire from the battery, there should be a fuse close to the battery to protect the wire run, rated a little less than the wire can safely carry for its length.
For instance, I want to have a plug (large two prong plug) in the back to run an inverter, compressor, or whatever. So, I have run a 4ga. wire to the back, protected by a 70 amp fuse at the battery end.
If I decide to connect a 12 volt socket to the 4ga. wire in the rear, I would figure the amperage I want it to handle, and connect the appropriate gage wire, with an appropriate fuse at the connection, to protect the wire that goes to the socket.
