roof leak please help!!!!
Old Apr 20, 2012 | 04:12 PM
firefighter22's Avatar
Default roof leak please help!!!!
I have a 2012 jeep wrangler 4 door hard top and it seems to leak around the sound board especially around the screws that connect the roll bar to the driver and passenger removable roof. Anyone have suggestions what to do?
Old Apr 20, 2012 | 04:17 PM
balmorjk's Avatar
Under warranty, take to dealer for fix.
Old Apr 20, 2012 | 04:47 PM
jkrubcon's Avatar
I use a NAPA product called Sil-Glyde. Take everything apart, coat all seals using your finger. Reassemble everything, take your time! Take it to the car wash, enjoy! This stuff should be 50 bucks a tube, I use it on everything. It's 6 bucks. When ever I'm in napa I buy a tube, might be gone someday.
Old Apr 21, 2012 | 04:03 PM
JKcondrey's Avatar
Second the warranty suggestion. I would check the alignment of the panels too. May just need some adjustment. I bought a used top on there that leaked horribly(due to NO gaskets ) Bought new ones, installed and it works great. I firmly believe the orientation of the gaskets is the root cause of every leak thread on here.
Old Apr 21, 2012 | 05:47 PM
Sparkplug's Avatar
Common problem. Dealer. Warranty. Rental.
Old Apr 21, 2012 | 06:19 PM
jkrubcon's Avatar
Good luck with that! Read some of the other threads on this forum. They either say they fixed it or they can't find it.
Old Apr 26, 2012 | 07:08 PM
-AINOKEA-'s Avatar
I took my 2011 JKU in to the dealer 5 times for a hard top leak. On the 5th time they said they found a new gasket with a different part number. Havent had a leak since. Mine was leaking from somewhere up front though near the top of the windshield and coming down the the back side of the front passenger door. I would highly recommend taking it to the dealer to fix it. It is a very common problem.
Old May 10, 2012 | 05:31 PM
scratchkenny's Avatar
Default water leak location and fixes
I found this link one day when I noticed my new jeep floor full of water. took it back to the dealer, they replaced the door seals, didnt work. I came home and did some lookin on line and found this site. Fixed my leak no problem.. Hope this works for you.
[URL="http://www.jeep-club.net/graphics/manuals/85/JK_Water_Leaks_All.pdf"]
