Sprint Booster Install
#21
I tried installing the Sprint Booster today, but to no avail! It took me about 15 minutes just to get in a position that I could even see and get my hands up there to disconnect the gas pedal plug...what a PITA!
I ended up giving up, as light was fading.
Am I missing something? Any suggestions on how to do this?
#22
#23
SprintBooster not working !!!
Just "tried" installing the sprintbooster on a manual 6sp
2 door 2008 JK. Put the key in the ignition, without turning it at all and left the door open for 5 minutes as per instructions.... disconnected stock plug and plugged it into the Booster and the booster into the accelerator
inlet. Problems: 1) engine light is ON
2) start engine and it surges to 2.5k RPM's, and remains there, pressing the gass pedal has no affect.
3) Sprintbooster button not lit nor responsive.
Turned off engine and disconnected device, reconnected stock, all back to normal, engine light off and gas pedal responsive.
tried the installation again, thinking that maybe the instructions mean to put the key in turn it while still in the off position, b4 the bells and dash light come on with the door open.
BUT had the same result.
WHAT AM I doing WRONG?? I can't be the only one that has experienced this problem?? Is it a bad Unit?
Bought from Quadratec, correct model for manual trans etc...
any suggestions?
any suggestions?
#25
Problem
Well to the one guy that has it rev to 2500. You connected it to the pedal backwards. I did the same thing. I figured who needed instructions haha. But now I'm having the problem where it won't change off of a green light. It just stays on wont even turn off. Any ideas
