Steering wheel knock/klunk on 2012?
Old Aug 30, 2011 | 04:18 AM
onlylive1's Avatar
Default Since 2007...
I had the clunk in my 2007 and after greasing the shaft I have not had any trouble (over 2 years ago). It is a shame that Jeep did not fix this issue in the newer models. This has been an issue since the JK came out......
Old Sep 2, 2011 | 03:56 PM
Ape's Avatar
Ape
I find it odd that my 2009 never had it. And now I have with the 2012.
Old Sep 5, 2011 | 01:04 PM
brianelms's Avatar
Thumbs up
I got so fed up with the clunking in my 2011 that i finally broke down and did this "mod" also. with only 200km since, still no clunking since i filled the boot with 5th wheel grease. highly recomended.
Old Sep 7, 2011 | 10:46 PM
J.Clarke's Avatar
hey I don't know if this is totally related or not but it may be the cause of the problem along side the other suggestions, but i have had a similar problem with my other cars (Cobalt SS and Corrado VR6) [considering both cars are lowered] if i hit a bump hard enough it would knock my control arm bushings out a bit and it would make a knocking noise that could be felt in the steering wheel when you go over a bump, and would give the feeling of the steering wheel knocking, but its just the metal, they are pretty easy to fix yourself (well for me anyways cause i had to fix them a number of times). but that could be a cause, but at the same time you wont know until you check it out it seems highly improbable because it being a jeep and all and being ment to hit bumps and what not without a problem.... let me know!
Old Sep 9, 2011 | 04:01 PM
jeepmont's Avatar
Just bought a 2012 and i have the clunk. need to do the mod since its getting very annoying.
Old Sep 13, 2011 | 05:57 AM
JKnewb's Avatar
I had an 07 JK with the clunky steering issue. I traded it in for a 12 JKU. I only have about 600 miles on it so far but I'm starting to experience a clunking again but it seems different. When I hit a bump or uneven pavement I can feel it from the left drivers wheel as well as the steering wheel. I'm going to make an appt and bring it in for a look when I get a chance.
Old Oct 7, 2011 | 04:12 AM
dmwil's Avatar
How do you put the grease in a grease gun? Do you pour it or squeeze it in? Does it make a mess of the grease gun?
Old Oct 7, 2011 | 05:08 AM
yo_marc's Avatar
The grease gun will disassemble into two parts, by unscrewing the body from the pump section. You slip a grease cartridge of your choice into the body, and screw it back onto the pump section. It's very easy. Sometimes a little messy.
Old Oct 7, 2011 | 11:17 PM
STCjpr's Avatar
My 2010 had the thump, my 2011 is starting to get the thump, and hopefully my 2012 will live up to that expectation too...
Old Oct 8, 2011 | 06:55 PM
dmwil's Avatar
The only Lucas Oil 5th wheel grease I've seen comes in a bottle, not a grease gun tube. What I was wondering is if there is a way to put it in a grease gun, or cut the nipple so that it goes over the fitting on the needle. How have others done this, or does it come in a grease gun tube?
