Stock Bumper "Mid-width" chop job with winch plate
#21
Found this link from your post in the stubbie 101 from tinman thread.... nice job dude. I think will finally do it for me. I can see the cuts on the metal bumper parts and the measurements and what to leave. AWESOME!!!!
The only thing I noticed different is the angle or taper of cut between you and tinman. Yours is straight from top to bottom whereas tinmans follows the contour of the crush can bump.... any advantage or disadvantages to each design?
Thanks a ton dude... this will look great.... yep I agree... should've come this way from factory!
#22
#24
Thanks for the great write-up! I decided (nervously) to give it a shot and it turned out great. First time cutting on my 3-week old Rubi but it wasn't too bad, took the better part of the day to complete. Here's some shots:
#25
I LOVE this mod!! Just did mine, I used a jigsaw with a metal-cutting blade to cut the inner bumper and then just swapped to a wood blade and turned down the speed to cut the plastic part. Worked great!!
Also, I almost missed the part about using those washers, but I'm glad to say I noticed that part right before I went to Home Depot, I really think that adds a tremendous amount of strength! Don't think it would be near as sturdy without them.
Looks great, can't believe I waited so long to do this. The first cut really is the hardest, but look at it this way: If you mess up, there are loads of factory bumpers available on here for cheap or for free.
Haven't bedlinered mine yet, but I like the looks anyway. When I get 10 extra bucks, I'll throw that on too.
Anybody used Rustoleum's bedliner spray? The autoparts store by my house didn't carry duplicolor, which I have heard great things about.
#26
#27
Thanks again for taking the time to post it! I painted the first one with bed-liner and the bed-liner paint started flaking off. So when I smacked the bumper on a waterfall face and ruined it I did this second one. The wife likes the rivets too much so no paint this time.
#29
Well Right in the middle of doing my winch and bumper changes I find this thread. What do you know, it is the exact same thing I was in the middle of doing and I love it!!. Heres my before and after.
Parts and Pieces,
XRC8 Winch 299.99
Harbor Freight Universal Winch Plate 38.95 (Only a slight modification is needed to make this work, very simple)
1/8 Inch Rivets to hold encaps back on,
I have a few more pictures of random stuff of the build, let me know if anyone is interested
-david
Parts and Pieces,
XRC8 Winch 299.99
-david
#30
Looks awesome guys!!! Keep up the great work! Remember, if you're gonna shoot the bumper over with Duplicolor Bedliner...2 things you're gonna want to do:
#1) Before doing "any" spraying...you'll want to fill in the holes in the tops of the rivets. I did mine by using a soldering iron and some of the left over plastic from the bumper chop. All you need to do is melt a little bit of plastic into the rivet hole then let it cool off. Hit it with a light sandpaper...I mean barely (or you might pop out the plastic plug you just made). Sand smooth so the top of the rivet is now closed and flush.
#2) THEN, spray the entire bumper with Adehesion Promoter...you'll need to work fast here and the window of time is like 10 minutes or so. When the adhesion promoter starts to get milky or white looking - you need to start spraying on the Bedliner. Remeber, 1 light coat of bedliner 1st, then go over the whole thing again. This will assure a nice even finish. If you did step #1 above, after the bedliner is completed, your rivets will look much neater as there is no hole on the head of the rivets.
Have fun choppin and keep posting up your pics!!
