Sun visor mod
#81
can't we just spray-paint them?
(mine is 2010... you can tell just by looking at them that they wont come out easy)
they are kinda glossy, so i don't know if rattle can spray paint will work... what do you think? just flat black?...
#82
Well I started taking my stickers off and like some of you already said, they must have changed the stickers because they do not just pull right off. I tried using my finger nail which got it started but did not remove much after about 30 min. I then tried using a hair dryer to heat up the sticker which at first looked like it was going to work but the heat started to mess up the visor material. I found that a razor blade works with a little care. Use the tip of the blade to get under the sticker, push the non-sharp edge against the sticker as you pry it away from the visor. I found that it works best to take the sticker off in 1/4 in. strips at a time. I'm slowly working on this a little at a time. I'm about half way done with the driver's side with no damge to the visor. Side note....Take the visor off the vehicle to do this. It makes it so much more comfortable to work on it.
#84
maybe it would be nice to see some pics of those 2010 warning stickers that didn't want to come off and left just a mess, just to have an idea on how bad it can get and see if one can figure out another way.
BTW... anyone on the painting solution?
#85
Mark
