Tera Quick Disco's
Something like this just might help a few guy's, I know I learned most everything from this forum.
These are what I purchased & Installed(Teraflex Quick Disconnect's)
Ordered from "Quadratec". You actually get 2 extra "Pins" with kit, not shown in picture.[IMG]
[/IMG]
Remove Stock Link's ..just Unbolt Both Ends & Remove......
Bolt both Tera Quick Disco Links top Bolt only ....
Bolt these Pin's(Shown in Pic below) to Bottom hole on both sides.....
[IMG]
[/IMG]
Picture of Teraflex Quick Disco Link Connected.
[IMG]
[/IMG]
Pulling "Lock Pin" out....I bought these at Lowe's & they lock securely( better).
[IMG]
[/IMG]
Lock Pin removed & now removing the Washer
[IMG]
[/IMG]
Pull Swaybar off Pin.. now you are Disconnected.
[IMG]
[/IMG]
Disconnect other Link & pull Swaybar up an Park both left & right side links on Parking Pin.
[IMG]
[/IMG]
If you are not perfectly level there will be a slight mis-alignment when trying re-connect them, I just put my knee ((while squatted down)) under the end of the bumper, it lifts very easily to so you can get the proper alignment to get it on. Done.
[/IMG]Remove Stock Link's ..just Unbolt Both Ends & Remove......
[IMG]
[/IMG]Picture of Teraflex Quick Disco Link Connected.
[IMG]
[/IMG]Pulling "Lock Pin" out....I bought these at Lowe's & they lock securely( better).
[IMG]
[/IMG]Lock Pin removed & now removing the Washer
[IMG]
[/IMG]Pull Swaybar off Pin.. now you are Disconnected.
[IMG]
[/IMG]Disconnect other Link & pull Swaybar up an Park both left & right side links on Parking Pin.
[IMG]
[/IMG]If you are not perfectly level there will be a slight mis-alignment when trying re-connect them, I just put my knee ((while squatted down)) under the end of the bumper, it lifts very easily to so you can get the proper alignment to get it on. Done.
yeah,,this are my first disco's ,,so did not have any idea as the intructions ara black! :sad: but this pics did the trick,,they are installed,,,! now,,
im thinking i may need front brake line extentions though,,,have the teraflex
2.5 BB on it.
2.5 BB on it.
Just got my discos installed and it maybe took an hour. Also wanted to let anyone know who may be considering the Teras that they have a new safety pin that looks a little more secure than the one pictured(from Tera in top picture) in this write up. I tested it out and it is easy to disconnect and reconnect. I like the Teras because they have a place to park with no loose pieces when disconnected. I hate zip ties and bungies!
