Tip for Freedom Top
Old May 23, 2007 | 04:27 PM
priell3's Avatar
Default Tip for Freedom Top
Ever have a problem with the rubber pads falling off from the header panel latch when removing the front panels?
Here is my quick fix - a small screw like this:
And the results:
No more falling off and getting lost.
Old May 23, 2007 | 04:53 PM
possumface's Avatar
i think yours looks different then mine somehow i don't think i have big rubber thing, just a small piece of foam sticky stuff that has moved about some
Old May 23, 2007 | 05:10 PM
njch412's Avatar
The rubber ones fell off one side of my soft top. I just found it on the floor of my jeep and was like wtf is this? Think I tossed it on accident.
Old May 23, 2007 | 05:59 PM
Wolfshead's Avatar
Same here...no rubber thingy, just felt patch....
Old May 23, 2007 | 06:04 PM
CincyJK's Avatar
i've just got the sticky felt patch too. could it be a difference in build dates?
Old May 23, 2007 | 06:10 PM
priell3's Avatar
Mine was built Feb. 2007.
Old May 23, 2007 | 08:17 PM
thrash's Avatar
Default Felt Patch...
Mine HAD the sticky felt patch.... long since fallen off and gone away.
I am contemplating what to do for a replacement for it....
Old May 24, 2007 | 05:04 AM
CincyJK's Avatar
same here. if you come up with something, let us know.
Old May 24, 2007 | 12:41 PM
duffman's Avatar
It looks like they improved the design a bit. I have a felt sticky patch on my top that has fallen off, moved around and now does not seal the front as well because it is now about half the width it used to be. The version pictured here looks much better.
Old May 24, 2007 | 01:00 PM
possumface's Avatar
im not sure what could replace this and still hold up under its use of latching & unlatching must be something rubber like or soft but still stay put . could be a mod thats needs dreaming up now who has a plan of action ..........band aid, rubber band glued on, another felt patch with sticky tar like glue . rubber grommet cut & silicone, and last but not least my duct tape
