Toggle switch installation question.
There's probably a write up on this already but my search skills aren't that great.
Here's my question:
I recently installed power cables to the front and the rear of my JK to power a winch. However the power is connected to a solenoid that has a switch to turn the power on and off. The toggle switch requires one wire to the solenoid, one to Ground, and one to positive on the switch side of ignition. The kit comes with a red wire with a fuse and splice clip. I need to know what's a good wire and its color code to splice into. Preferably on the Driver's side by the parking brake if possible. Any help would be much appreciated.
Here's my question:
Here's my question:
Here's my question:
Are you using a winch on a hitch adapter plate? I have been thinking of doing that.
Just out of curiosity, what size wire did you run to the rear of the Jeep for winch power?
what part of the dash needs to be disassembled? I'm not sure what the power outlet looks like or what color the wire is?
Here's a few pics of my front and rear hitch setup with quick connectors.
Attachment 137960
Attachment 137961
Attachment 137962
Attachment 137963
Attachment 137960
Attachment 137961
Attachment 137962
Attachment 137963
Not sure what you mean by inserts. On the front I have a skid plate that mounts into the reciever, it helps keep mud out of the reciever and gives a little more protection. the small silver barbell is a locking reciever lock. Both front and back are keyed alike. and the red part is the quick connect.
