Transmission Drain plug link
Old Jun 10, 2015 | 08:44 AM
JeepinCO's Avatar
Default Transmission Drain plug link
Does anyone know if there's a link to a write up on putting a drain plug in the AT pan? I plan on changing my ATF next week, and I'd like to add this to it.
Old Jun 12, 2015 | 07:11 PM
Mike Davis's Avatar
Default Trans pan drain
A friend had a pan that he had a drain plug welded in and painted. He put it on my 08. I sent him your question, hopefully you'll hear back from him ..ronjenx. Btw, be sure you have a new filter and understand the exact way to apply the silicone sealant. A new pan is fairly cheap. Buy one to get the work done before you start the job. You'll also need ball headed allens and ratcheting wrenches. I do believe he did a tranny fluid/filter write-up.
Old Jun 12, 2015 | 07:18 PM
Mike Davis's Avatar
Default Tranny fluid
See https://www.jk-forum.com/forums/jk-w...-change-42719/
QUOTE=Mike Davis;4110705]A friend had a pan that he had a drain plug welded in and painted. He put it on my 08. I sent him your question, hopefully you'll hear back from him ..ronjenx. Btw, be sure you have a new filter and understand the exact way to apply the silicone sealant. A new pan is fairly cheap. Buy one to get the work done before you start the job. You'll also need ball headed allens and ratcheting wrenches. I do believe he did a tranny fluid/filter write-up.[/QUOTE]
Old Jun 12, 2015 | 08:03 PM
ronjenx's Avatar
Fill out your profile so people can see what year your JK is, and what it has for equipment.
The following applies to the 42RLE transmission, '07 to '11 JK.
Weld a bung in the pan. I cut it down a little to reduce its height from that shown in this picture.
Make a tab with a small hole in it, and weld it next to the drain plug. Safety wire the plug to the tab.
This wrench and cap screw combination will make the three screws over the exhaust cross-over much easier to install. The ball-ended Allen wrenches make it so a straight shot at the screws is not necessary.
Old Jun 13, 2015 | 07:54 PM
Tombstone17's Avatar
We also added a magnet to our drain plug.....
Old Jun 13, 2015 | 08:08 PM
ronjenx's Avatar
Added a magnet? Or you found a plug with one built into it?
I didn't look too hard for one because there is already a magnet in the pan.
Old Jun 14, 2015 | 01:48 PM
One on the plug,
