Trimming Rubicon sliders
I was sick of the OE Rubicon slider/rock rails rubbing my left rear tire when I had a full load of lard butts and went over some whoops in the road,
not to mention at even partial flex, so I got out the grinder!
Heres what the problem looked like in stock trim:
And here from above:
On the right side too:
(from when I put this tires and lift on this Spring)
Of couse the pinch weld is also in the way:
So I removed the rails and after removing the end caps:
I marked out a line approx an inch back all the way around, got out the die grinder and had at it:
It took about 15 min per side of spraying sparks and pissing off the neighbors but ended up with these when done:
Next had to trim and touch up the pinch welds:
After spraying with some Rustoleum textured spray paint, reinstalled and had
at least an inch better clearance:
Thanks for reading
Thanks for reading
I did the same thing, but did it much quicker (Note: I don't really care about cosmetics):
Sawzall right to the sliders and pinch welds. I cut a lot more off so that it was flush with the fender flare. I lopped off both sides in less than 5 min. I then Sealed the hole in the pinch weld with some black silicone sealant. I left the slider hole open and then sprayed everything with black rustoleum.
Start to finish was less than 30 min.
