Tube Fender's a-custom
Old Dec 1, 2013 | 08:53 AM
  #21
blockrockin's Avatar
Originally Posted by TheDirtman
14 gauge is plenty strong.
agreed. i used 14 gauge and they are solid. river raider uses 14 g on their flares also
Old Dec 1, 2013 | 09:01 AM
  #22
TheDirtman's Avatar
So I dunno, maybe I'll bed line the lower part of the Jeep to "fix" it. I'll figure it out later, I'm jus happy that I now get to move on to bending tube [/QUOTE]
I had a local machine shop bend me up some 6"x 3/16" bar stock to match the bend in the lower rocker panel then I welded on some more bar stock to tie into the body mounts. Cheap and very stout. Cost $40 a side including the steel.
Old Dec 1, 2013 | 09:02 AM
  #23
TheDirtman's Avatar
I had a local machine shop bend me up some 6"x 3/16" bar stock to match the bend in the lower rocker panel then I welded on some more bar stock to tie into the body mounts. Cheap and very stout. Cost $40 a side including the steel. Gives it a boat side look and maxes your side clearance.
Old Dec 1, 2013 | 09:08 AM
  #24
TheDirtman's Avatar
Not sure on how you plan to attach the skin but I think you will want those mount brackets to go to within about 3/16" of the factory end in the opening so you have a clean edge to weld the skin to.
Old Dec 1, 2013 | 09:44 AM
  #25
SeverePatronage's Avatar
Dirt man, I'd live to see pictures of your rails, as long as the op is ok with it of course. Don't want to thread-jack.
Old Dec 1, 2013 | 10:12 AM
  #26
Old Dec 1, 2013 | 10:51 AM
  #27
sm_rubi's Avatar
Love to see DIY projects...subscribed!
Old Dec 1, 2013 | 10:55 AM
  #28
all4wheels's Avatar
Originally Posted by HardRooster
Built my driver side flange this morning in 90 minutes, something that took me all day to do yesterday. That's a big relief since I really wanted to be bending tube and building the frame brackets today. I thought it would take me longer, but I guess I spent way more time going backwards yesterday than I realized.
I also found this yesterday, confirmation that the stock Rubi rails are junk. I saw that they were bent, but I didn't realize how much they impacted the body until I actually removed them. This is just an example, but on both sides of the jeep, the rockers, quarter ends and fenders are damaged to the point of cracking the paint. You can see it if you look past my ugly weld
Yea you cant have a slider attached to the pinch seem prime example as to why......
Old Dec 1, 2013 | 10:59 AM
  #29
all4wheels's Avatar
attach a skin to it, it will cover that all up and give it strength.
Old Dec 1, 2013 | 11:18 AM
  #30
HardRooster's Avatar
Do you have any pics of this? I get the idea I think. I assume you also bolted it to the pinch seam? Did you rivnut the upper portion?
