Wiring fogs to headlights?
Your fuse panel is actually a computer and doing so you could definatly damage the circuit board and void the electrical waranty for your vehicle. On a lighter note you can have your dealer program your fuse panel(TIPM) to keep your fog lights on after you turn on your high beams.
Im thinking just unplug the fog light harness and let hang. then new harness and tap into the headlight power wire. think this will cause an issue? i dont see it
then again, havent even looked at it yet, just sitting here thinking
The problem isn't as much how to do it, it is will it overload the TIPM(Totally Integrated Power Module). Being here at the Dealer I get to see it all the time. The bulb could draw too many amps through the circuit board and/or relay and now your looking at $700+ dollar repair(unless your close and then I can hook you up). Don't know if it's worth the risk over a simple pull out switch.
