Write-Up: Removing Backseat (2dr)
No, I'm not kidding... The owner's book gives a pretty good description of how to remove the backseat in a 2 door, but seeing as I just did this myself all of 5 minutes ago (and found a shortcut) figured I'd share with the group.
I have the subwoofer, which the Jeep manual says to remove and disconnect prior to removing the backseat... don't bother (if you're strong enough to handle the seat by yourself, this is a total waste of time).
OK - in step-by-step form:
1) Open the tailgate and rear hatch (if you have the soft top on, tie the rear windshield panel out of your way). Climb into the "cargo" area.
2) Use the "fold-and-tumble" feature (you may need to adjust your front seats to provide enough clearance for the backseat to pivot forward properly - this is important).
3) Squeeze the pressure bar at each side, where the folded seat attaches to the cargo floor - you don't have to squeeze particularly hard, but you WILL need to squeeze to disengage the floor clasps from their mounts.
4) Lift FIRMLY upwards and backwards while squeezing the pressure bar - the goal here is to disengage the clasps from the floor mounts. Not very heavy, just awkward to do (go ahead and get mad at it, then give it a good tug - worked for me).
5) CAREFULLY pull the folded, disconnected backseat backwards toward the rear opening - if you have the subwoofer and left it installed, exercise care not to smash it, etc.
6) Gently stand the backseat on its end behind your Jeep - climb out.
7) Store the rear seat wherever, and enjoy the newfound rear visibility, cargo space, and extra 1/3 mpg!
How much of a mechanical rookie do you have to be to get a profound feeling of satisfaction from doing this all on your own? (That's me!)
Thanks, Just did this to my new 2011 Rubi... It did not come with any manuals... Just a window sticker and a tire warranty booklet...
Did a serch and wa'lah... Thanks again...
Removing back seat on 2 door JK
I know this is an old thread, but does anyone have any pics of what the "seatless" rear on a 2-door looks like? I'm pondering taking mine out since it's more of a hindrance to me anyway, but wanted to see the final product before I do it myself.
Originally Posted by Nickit1981
Dude.. do yourself a favor and just take it out.. it takes 2 minutes of our day and if you don't like it.. 2 minutes more to put it back in.
