el paso and surrounding areas bs thread
#1022
It's the clip that holds the linkage, zip tie it for now and then order a bunch from the local dealer, I'll get the part number here in a sec...
#1023
I called him, the bushing is in place on the TC side, looks like it's either at the shift lever or the cable broke. Not sure how much the stock one costs but if the cable broke I'd do the Advanced Adapters cable. I've had that on my "someday" list for a long time.
#1024
Hmmm, that's different... FWIW the part number is 1-68064273AA the cost is like 30 cents and they're fragile as all get out which leads to my surprise it's not the clip...
#1025
Dont do it. Get a similar peice from the hardware store with a metal E clip (search forum) or usr the four wheeler body wiring gusset... also metal amd on this forum.
Oh, dony YANK the lever. EASE IT IN.
#1026
It was the link under the console. Not under warranty anymore. I was able to use a crow bar to pry the little knob on the transfer case back into 2 wheel drive to get home. I tried taking the console off but it was a major pain. Ill be fixing it this weekend after I pick up a new link at the dealer.
#1027
Originally Posted by CH10
I'm Jason that you just talked to. Let me know if you can't get the linkage to move and need some help. I'm on the east side.
#1028
#1030
Discovered a small drip....its clear...doesn't have an odor...nor did it stain the drive way....can't figure out where its coming from...I'm at work so I can't get under there...I haven't been running the AC.....any ideas?....its not greasy it washes off easy off my hands...
