Member Video Creations Please post your favorite JK related video link here. Members only please.
Pro Comp 1.75" spacer lift install
Old 03-29-2016, 05:01 AM
CRAWL TV's Avatar
Default Pro Comp 1.75" spacer lift install
We threw in a 1.75" spacer lift to tuck our 35s in while we wait on our rear fox shocks that are on back-order. As soon as they show up, we'll be upgrading to the full 4.5" Synergy lift with Tom Woods driveshafts.
https://youtu.be/I3GIBZoxX40
Old 03-31-2016, 07:30 AM
Avrgmike's Avatar
How much higher overall does this make the roofline between the level kit n tires ? Unfortunately I park under a deck and I'm limited on height. My 16 Jku has about 3-4" clearance stock. Looking at this w/ 33" tires. Any info is much appreciated. I'll also search n see if maybe others have specs. Ty
Old 03-31-2016, 12:39 PM
CRAWL TV's Avatar
I can't tell you the exact amount from stock since I didn't measure it, but the highest point on the Jeep from level ground is now 75" with 35s, so I'd assume you'd be around 74"...
Old 03-31-2016, 12:40 PM
CRAWL TV's Avatar
Here's a better shot of it.
Old 04-01-2016, 03:38 AM
Avrgmike's Avatar
Awesome tyvm. Ill measure mine I may be able to fit that kit w the 33"s. Being they will be a little lower then 35's sweet.
Old 04-04-2016, 07:25 AM
Avrgmike's Avatar
And my hopes r crushed now. Just swapped to my soft top and didn't realize the bows on it r higher. So I barely fit under my deck. No level kit for me.
Old 04-04-2016, 08:58 AM
CRAWL TV's Avatar
Sounds like it's time to stop parking under that then. You don't need that kind of negativity in your life. 😂
Quick Reply: Pro Comp 1.75" spacer lift install
