Manual Transmission Drain Tool
Old Aug 21, 2010 | 05:34 PM
u-joint's Avatar
Default Manual Transmission Drain Tool
I just thought I'd throw this one out there for all the Tulsa area JKers....
I spent 2 or 3 hours driving all over Tulsa looking for a 17mm Hex bit and another 2.5 hours grinding it down into a useful size to use on the manual transmission drain port.
If any of you stick shifting JKers in or around Tulsa need to change your transmission fluid hit me up and I'll help lend a hand (schedule permitting).
Changing the fluid is literally a 15 minute job once you have the right tools
Old Aug 22, 2010 | 07:23 AM
0259brian's Avatar
there is a write up on this at project jk.com.
Old Aug 22, 2010 | 07:38 AM
u-joint's Avatar
Yep, that's where I get the idea from
Still requires grinding
Old Aug 22, 2010 | 07:47 AM
0259brian's Avatar
i went the coupler nut route. figured it would be softer for cutting. used a dremel tool for the cutting. what did you use to get the fluid in the trans and transfer case
Old Aug 22, 2010 | 10:58 AM
u-joint's Avatar
I picked up two of these at Atwoods:
They are labeled "Marine Lower Unit, Flush and Fill Pump"... not sure what a "Marine Lower Unit" is, but if you simply remove that silver screw looking thing at the end of the hose it instantly becomes a "Transmission and/or Transfer Case Fluid Pump"
They are from a company called Lumax and the part number is LX-1348. They fit standard quart sized bottles.
Old Aug 25, 2010 | 05:42 PM
0259brian's Avatar
Attachment 82997
how does it pump?. i used a suction gun would not recommend that very frustrating. i may have to get two one for the transfer case and one for the transmission
Old Aug 25, 2010 | 05:44 PM
SilverJK12's Avatar
I will definitely give ya a shout.
Old Aug 25, 2010 | 05:48 PM
u-joint's Avatar
It pumps very well.
For a whole quart I probably had to pump 50+ times, so it took a few minutes to do a single quart. But, there is relatively little back pressure while pumping, so 50 pumps sounds like it would have made my arms very sore, but surprisingly not.
Since the manual transmission fill port is up much higher than the transfer case's, I had to put the quart bottle on my stomach so the tube would reach. Even then, it was luckily not painful.
I'd highly recommend you try and find a couple.
Old Aug 25, 2010 | 07:38 PM
u-joint's Avatar
Yeah, any time. I always enjoy working on Jeeps.
When your ready just let me know and we'll work out a date.
