OK bs
Old Mar 28, 2011 | 04:04 PM
  #4911
snowbilt's Avatar
Originally Posted by Love Monkey
Takes up a lot of room for camping gear....do you care about seeing past it? Hmmm... How would you secure it?
Bondage Tape?
Old Mar 28, 2011 | 04:08 PM
  #4912
Coondog33's Avatar
I'm in the brainstorming process...I'm 6-6..not worried bout looking over it..if I need space(camping)..ill renount it...but for 99% of my daily routine..ill have enough room..keep thoughts coming..
Old Mar 28, 2011 | 04:10 PM
  #4913
Love Monkey's Avatar
Originally Posted by snowbilt
Bondage Tape?
Just not the pink stuff...& I'm not sure it'll hold when its hot.
Speaking of which...thinking warm for you guys.
Sent from my Incredible in Tapatalk Pro
Old Mar 28, 2011 | 04:12 PM
  #4914
Coondog33's Avatar
Love..your not helping with temp posts..especially while I'm in garage..
Old Mar 28, 2011 | 04:14 PM
  #4915
snowbilt's Avatar
I am 6'6" too. Man somebody needs to start producing a seat relocator bracket for the JK...On a serious note maybe you could drill some ties on each side of the wheel and put some type of netting over it and tighten down on each side. and maybe put two tabs on the front and back and secure it down with some type of cable too. That would be a big object flying around if you got in an accident. Will it lay flat?
Old Mar 28, 2011 | 04:18 PM
  #4916
Sorry
Old Mar 28, 2011 | 04:19 PM
  #4917
Coondog33's Avatar
It will lay down..I'm trying to stand it up for space..it'd be perfect if I could figure out a way..I like Ur idea a lot..
  #4918
Coondog33's Avatar
Sorry
I was j/k..
Old Mar 28, 2011 | 04:23 PM
  #4919
DiFfErEnT's Avatar
I had my standing up along the side behind the passenger seat in my 2 door....I used a ratchet strap to secure it to the side of the jeep using the provided holes along the body for the hardtop....Just some food for thought
Old Mar 28, 2011 | 04:24 PM
  #4920
Red-Dirt's Avatar
Ok guys and gals...question number 1 of the night...is there a problem with this spare tire set up...as long as I get it secure...opinions...
I would lean it back just a little more on the seat, then I would find some cables or ratchet strap you can run through the spokes of the wheels, or the gap between the spokes...have some padding like a shoulder belt that you can use to surround the cable/strap where it is running through the wheel so it wont wear off the finish on the wheel, then secure the cables/strap on each side to the rollcage. it should hold it pretty sturdy i would think. Hope that made some sense.
