Is $1,900 too much?
Old Dec 11, 2009 | 09:52 AM
  #21
NE Wrangling's Avatar
Well I don't think it's to much higher than I would of guessed for the reasons mentioned in previous posts. If they are estimating 20 hrs for the lift based on the manufacturer that is probablly a little high if they have experience with the lift. I'm wondering how they plan to squeeze in the c gussets. They first need to clean off the axle grinding any crap off and then prep by moving stuff out of the way. Overall, that will take time without causing to much heat to damage parts around it. you can do it without moving much but it is obviously easier to drop the axle.
  #22
UGOTKERN's Avatar
Noticed 4wheelparts is offering 25% off installs. Does the $1900 labor cost reflect the 25% off?
Old Dec 11, 2009 | 11:00 AM
  #23
08{GA}RUBICON's Avatar
I bet you would have to buy the lift from them. I purchased the lift from Tera Flex (Joe) here on the forum.
So how about $1,100? Offroad Outfiters is doing it to include the C Gussets, Lift and alingment. I'll pay that to also get a warranty on the work they do! Thanks JoeBlob for the recommendation. They have also done the lift, have a tech that worked for Tera Flex and said it would on take about 16 hours.
Old Dec 11, 2009 | 11:21 AM
  #24
Piginajeep's Avatar
It took bruised and I about 16 hours for his weld on rockkrawler lift. We didn't work hard at all, 1100 isn't bad. I know if I was charging it would be atleast that. It's alot if work for a long arm Lift
Old Dec 11, 2009 | 02:27 PM
  #25
mkjeep's Avatar
Buy a welder and a torch, and let your friend help. Afterwards you'll have experience and a new welder and torch and money left over.
Old Dec 11, 2009 | 02:31 PM
  #26
TheonlyREDhead 2008 JK's Avatar
Do it with ur friends and if there are problems you will know how to tighten and adjust it yourself!
Good luck
Red
Old Dec 11, 2009 | 02:52 PM
  #27
Sethc84's Avatar
Good luck
Red
The best thing about doing your own lift is knowing how it works so you can do repairs whenever i.e trail or roadside. Otherwise the satisfaction when your done is pretty nice.
Old Dec 11, 2009 | 08:57 PM
  #28
nocoastfocus's Avatar
Agreed. Perfect time to buy a welder and learn.
