$160 to mount & balance ? whf
Old Jan 30, 2008 | 06:59 AM
pkdailey4's Avatar
Default $160 to mount & balance ? whf
A national chain 4 X shop wants to charge me $160 to m&b 5 tires and wheels. They said its so much because, we will take the tpms out of your old ones and put um in your new ones. they also wood like me to hand over $30 for lug nuts, $15 for stems & $20 for lead for grand total or $225 w/o tax, Does this sound like a smokin hot, sign me up now deal to you guys too???? how m uch would you pay ?
Old Jan 30, 2008 | 07:03 AM
saltman's Avatar
I just got 5 tires done. It was 68 dollars. I thought that was high. No TPMS though. It was an 07.
Old Jan 30, 2008 | 07:04 AM
fourwheelingbigbubba's Avatar
It's probably a chop shop, they know you got money because you got a brand new Jeep and they want some of it..
Old Jan 30, 2008 | 07:53 AM
purple11haze's Avatar
Default tpms
I though all JK came with lug nuts. From what my installer said, the tpms equipment is kind of expensive and a pain to do(I dont have tpms). Sounds kind of high are they installing 35" + tires, price some other shops.
Old Jan 30, 2008 | 07:57 AM
Northridge4x4's Avatar
Sponsoring Vendor
The tpms is simply the valve stem if you are reusing your old ones it is no big deal but if they are buying new ones that can add up they are approx $50-60 each.
If they are reusing your old ones all they have to do is unscrew them after they dismount the tire and they will come right off.
Sounds way to expensive to me.
David
Old Jan 30, 2008 | 08:26 AM
flemgunner's Avatar
Just had mine done. Mounted 5 265/75/16's on mine cost me $50. Two places gave me the same quote for it
Glenn
Old Jan 30, 2008 | 08:40 AM
riverzendz's Avatar
I paid $75 for 5 17" 33's mounted and balanced which included swapping the TPMS over. It was also removing the tires from the old wheels and mounting them on the new. Oddly enough, you mentioned they are charge you for stems...but you need to keep the OEM stems to keep TPMS.
They're ripping you off. Laugh at them and walk away.
Old Jan 30, 2008 | 08:42 AM
mikeyfl's Avatar
good advice.
Old Jan 30, 2008 | 09:03 AM
tgrt's Avatar
Former Vendor
ripoff. Whats's the store? Help your fellow Jeepers out.
Old Jan 30, 2008 | 09:04 AM
BaltChief's Avatar
They are charging you $15 for new stems yet they are reusing your TPMS which are stems? ......are they drilling holes for the new stems so you will have 2 on each wheel .....They are screwing you.....turn and run
