0 EXPERIENCE !!! Shock Install
Old Apr 2, 2012 | 02:33 PM
robsjeep9's Avatar
JK-Forum Ambassador
Default 0 EXPERIENCE !!! Shock Install
Hi everyone thinking about installing
Bilstein 5100 shocks with Noooo Experience!!!
Easy to do? Any write ups??? Sorry on a iPhone. Thx
Old Apr 2, 2012 | 02:48 PM
JfK's Avatar
JfK
1 bolt, 1 nut. Piece of cake.
Old Apr 2, 2012 | 02:51 PM
Dayman's Avatar
Pretty easy install. Rears I did on the ground. Three bolts took about 15 min. Fronts were a little more stubborn. I suggest jacking the axel, jack stands under frame, remove tire. Hit with pb blaster in advance to help loosen the nuts. Bottom is easy to get to top is a little confined, invest in a ratcheting wrench to make it easier. I am by no means a mechanic and found this to be a easy install! Learned a lot about the jeep in the process.
Old Apr 2, 2012 | 03:11 PM
robsjeep9's Avatar
JK-Forum Ambassador
Mmmmm cake!!! Lol thx
Old Apr 2, 2012 | 03:12 PM
robsjeep9's Avatar
JK-Forum Ambassador
Ok thanks I'm learning alot too and really enjoying it.
Old Apr 2, 2012 | 03:26 PM
OH9JK's Avatar
JK-Forum Ambassador
The fronts will be much more difficult than the rear. The fronts also tend to have more rust on the studs because they are exposed....soak them with PB Blaster.
It is a good DIY project
Old Apr 2, 2012 | 03:55 PM
grover0878's Avatar
I did mine this weekend. Rears easy, front driver side easy, front passenger PITA. I have a 2012 and there was no way to get to the top fastener on the front passenger side, ended up using the dremel to get to it.
Old Apr 2, 2012 | 04:38 PM
robsjeep9's Avatar
JK-Forum Ambassador
Ok thanks everyone!!!
Do the bolts get TORQUED ? Or hand tightened? Thx
Old Apr 2, 2012 | 04:47 PM
OH9JK's Avatar
JK-Forum Ambassador
http://project-jk.com/jeep-jk-write-...orque-settings
Old Apr 2, 2012 | 04:51 PM
CreepJeep's Avatar
I had zero problems when I changed mine.
no rust, nothing was seized up.
It's really easy to do
