1/2" or 3/4" spacer
Just wondering who has installed a 1/2" or 3/4" spacer on either a stock or lifted jeep and calculated the results. Are the results higher or lower than stated.
I am not going to lift for now but want to level up the front. Installed a metal bumper but no winch.
I do not want the front higher than the rear and I know from previous installs of this type the stated lift is not the final result. Front seems to be between the two heights now when on level ground and gas tank full enough for both sides of the rear to measure equal
Any input appreciated.
I installed Teraflex 3/4" front spacers to even out the 3/4' drop caused by installing a Warn bumper, grill tube, winch mount, front skid plate, and Powerplant winch. Height remains close to factory height and so far no problems.
Thanks
Just did not want the front to high.
Quadratec sells both 3/4 and 1/2. link to the 1/2 below
http://www.quadratec.com/products/16190_1000.htm
