1/2" steel spacer on top of exsistng 2.5" spacer
Anyone put a 1/2" steel spacer on top of their existing 2.5" steel spacer ?
I have a 2013 JKU.
I measured the front and back from a level cement drive and notice a 1" difference front to back.
I want my JKU level with no rack. I used this RC 2.5" spacer lift on my 09 JK with no problems. But the JKU seems to sag more in the front than my JK did.
Pics of the members JKU's still look to have a slight rake to them after the spacer lifts they did.
Thanks for your comments and help.
I have a 2013 JKU.
I've thought about doing this as well, my bumper and winch drooped my front end a little bit. I have access to a lathe and free materials so I cant bring my self to spend any money on a plastic ring.
I have the Teraflex 2.5 coil lift but as long as you have the proper shock extensions/ shocks and clearance for the driveshaft I would think you'd be okay.
Tack welding the steel spacer in would probably be a good idea as well.
Do you have the measurements of the spacers? I cant find them anywhere, and I'm not too thrilled about removing a front coil for the hell of it.
