1 3/4 lift kit
Old Mar 30, 2010 | 09:19 AM
jeep 21's Avatar
Question 1 3/4 lift kit
I am wanting to lift my JK and keep my stock shocks 4 a while and not change any other major things 4 now. I have found a daystar kit on quadratec part #16058.100X and also a pro comp lift on ebay item #110470531370. Has anyone had any experience with either kit? Both look the same but would like some advice.
Old Mar 30, 2010 | 09:31 AM
jmat1980's Avatar
With 1.75 in of lift you won't need to do anything but add the spacers to the stock springs...
Old Mar 30, 2010 | 09:39 AM
jeep 21's Avatar
Yes this kit also comes with drop sway bar brackets for rear and bump stop extenders for front
Old Mar 30, 2010 | 09:41 AM
thom1879's Avatar
I have 1.75" spacers in the front. It would be a good idea to get longer swaybar links for the front.
Old Mar 30, 2010 | 09:42 AM
thom1879's Avatar
Oh nevermind, u posted after I started typing
Old Mar 30, 2010 | 09:43 AM
jeep 21's Avatar
but your talkin sway bar links 4 rear that's wat comes in kit and bump stops in front?
Old Mar 30, 2010 | 12:13 PM
Joisey's Avatar
Get a Teraflex leveling kit. 119.00 from northing ridge 4x4 and free shipping, easy install and it includes everything.
Old Mar 30, 2010 | 02:13 PM
porters's Avatar
I have 1.75" but it's Trail Master. Just got back from Moab and I was amased at what it was able to do with stock shocks and swaybar links.
Old Mar 30, 2010 | 04:10 PM
jeep 21's Avatar
Default tereflex leveling kit
I am in process of maybe picking one up off a member here 4 $60 shipped. But my jeep is almost level already it is maybe 1/4 inch lower in front barely noticeable. I do not want it higher in the front since i will be pulling a boat with my JK. Right now with boat it sits slightly lower in rear I would like to keep it that way. I believe the same lift all around would work out better than TF leveling kit.
Old Mar 30, 2010 | 08:11 PM
rubi08unlimited's Avatar
why the extended swaybar links with that small a spacer? I have those spacers and they compress to approx 1.5" under normal weight. if i disconnect the swaybar i get full flex anyway and I haven't had any issues yet. Do I need extended links?
