1.5" Wheel spacers HELP!
Don't retorque after applying red threadlock. It'll break the "lock". Install them correctly and forget about them. I ran them for 40k miles. One thing to note: three came off easy peezy. One of them however, froze to the rotor and it took a dead blow hammer and hot torch to remove it. It was a bitch. Not undoable if it happens, but no regular tire shop will remove them for you. Some tire shops won't even rotate ur tires if u have them. So ur" may be on ur own. Chrysler La Mesa in SD rotated mine and never mentioned anything about them. I'm sure they documented my use of them, so future warranty work, if needed, will be questionable. My lift doesn't help things out either, but...
I guess it depends on what you plan on doing. If you are wanting to keep the same wheels and tires but just want a little bit wider then yeah go for it. But you have to understand that it could ad stress to things if you do any kind of major wheelin. If you are changing your wheels then i would recommend just getting an offset wheel so you don't have to mess with spacers.
G2, teraflex and many others make 1.5" spacers. I've heard of people who have broken several sets of spidertrax. I have heard of people who have wheeled 10k miles on the Chinese Amazon brands. I personally used G2 spacers until I got new wheels with proper offset. What it comes down to is making sure that you install them correctly. Apply anti-seize to the hub, use a torque wrench and RED threadlocker on the studs, and use the torque wrench on your wheels as normal. Generally it is a 2 person install as you'll need someone to step on the brake. Just like with a tire rotation, make sure to torque the wheel spacers after about 100 miles as well as after any major wheeling trip.
I like this technique for getting the spacers "unstuck". One of mine got stuck, I had to use a blow torch and a bfh.
