1 more RK 2.5 flex install question. Front bump stop
Old Mar 3, 2013 | 02:37 PM
Learo2000GT's Avatar
Default 1 more RK 2.5 flex install question. Front bump stop
Thanks for the help along the way. Got to front bump install. Didn't come with directions. I have the RK bump stops. So do the bump stops go in addition to the stock bump stops? If so how much of the stock bump stock do I keep and how do I install them? I am running 35s on rubicon jku with bushwacker flat flares and fox 2.0 shocks if that info matters.
Thanks for all the help.
Old Mar 3, 2013 | 03:59 PM
Hydr0JKUR's Avatar
if they are the round metal ones they should go on the bottom of the spring perch, but u have to drill and tap a hole for the bolt
Old Mar 3, 2013 | 05:31 PM
Thanks. Do I add any part of the stock rubber bump stop or does that whole part get shit canned? Thanks in advance.
Old Mar 3, 2013 | 06:12 PM
So I think I found my answer. The bump stops go on bottom in addition to the stock uppers. Correct?
Old Mar 3, 2013 | 06:22 PM
Ncb's Avatar
Ncb
Yes. Keep the upper jounce bumper installed.
