11.5" D or 12.5" E Tire for 17x9 Wheel on 2 Door?
I have decided on a wheel and tire but I have a choice on the tire size and need some help. I have a 2-door red rock JK.
I am getting the Dick Cepek DC-2s (17x9 24 lbs 4-1/2" BS -12mm offset) and the Pro Comp Xtreme A/T. The Pro Comp Xtreme A/Ts are offered in a 285/70/17 load rating D and in a 305/65/17 load rating E. My initial choice is the D rated tire (8 ply) which is stated as having a 11.5" width. My concern is if this is too narrow for the 9" wheel. I currently have this tire on order but I have a week before it is in so I can still change. Should I choose the E rated tire which is stated to have a 12.5" width which is what I would prefer with the exception of the E load rating (10 ply)? :dontknow2: The majority of my driving will be on the highway as it is my DD (which is why I chose the A/T) but will occassionally do some offroad trails (nothing extreme). I'm staying with the 33" tire. Just the width is the only thing I am concerned with. |
These are the only 2 pics of mine that I could find with the 33x11.5 tire on a 17x9" wheel.
As you can see, there's certainly not much tire out to the side, but it looks fine. I would add that I would not want an "E" rated tire on a light weight vehicle like the JK. http://i108.photobucket.com/albums/n...IMG_0212-1.jpg http://i108.photobucket.com/albums/n...G_0564-1-2.jpg |
Originally Posted by zoeydad
(Post 1633724)
Originally Posted by JPop
(Post 1633734)
Continuation of the E rated Myth. There are plenty of C rated tires that are within 100 lbs of the tire mentioned and also plenty of D rated tires that have a heavier max load.
I am having trouble understanding the load ratings. I have read the posts which indicate maybe it doesn't matter but if it doesn't why even have the load ratings? :dontknow2:
If it is a significantly rougher ride then I will opt for the lower load ratings. I have never experimented with this and it is an expensive experiment so I'm hoping some good advice will solve this dilemma! :wink: |
Out of these two options I would go with the 12.5" wide tire, even though its E load, and just run it at a lower PSI... but thats just me.
I have the e rated tires (actually xtreme MT 315's). I honestly dont think it was noticeable at all when I switched from stock to the E rating. I noticed a bigger difference in ride when switching from RC suspension to TF (TF being better!)
Hope this helps! wish you were closer I am gettin ready to sell mine with only 2500 miles! |
Originally Posted by earnsdorff
(Post 1633978)
Thanks zoeydad for the pics!!!!
I looked at the Pro Comp ratings (they don't have the 285/70/17 tire listed yet) and the E rated 305/65/17 has the following ratings: Load Range E Max Load 3195 Tread Depth 20/32 Overall Diameter 32.6 Inches Black SideWall Sidewall Construction= 2-Ply The D rated tires were typically rated in the 3000 lb load range and up. Doesn't seem like much of a difference if any. The thing is if the load rating doesn't mean anything then what should I be looking at to choose my tire? :dontknow2: PS - Dog Doc why are you going to sell your tires? |
(Post 1634478)
I looked at the Pro Comp ratings (they don't have the 285/70/17 tire listed yet) and the E rated 305/65/17 has the following ratings: Load Range E Max Load 3195 Tread Depth 20/32 Overall Diameter 32.6 Inches Black SideWall Sidewall Construction= 2-Ply The D rated tires were typically rated in the 3000 lb load range and up. Doesn't seem like much of a difference if any. The thing is if the load rating doesn't mean anything then what should I be looking at to choose my tire? :dontknow2: PS - Dog Doc why are you going to sell your tires? One other thing to consider regarding Procomp's... They are freakin heavy in comparison to others. My tires(M/T) work great, with my only off road experience being mud as of yet, but it really changed the way the jeep drove, even only being "33's". It is a dog now and I only get 12-13 mpg!! |
| All times are GMT -8. The time now is 08:57 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
